Запчасти
Никакие детали не требуются.
  1. Insert the plastic opening tool under the faceplate.
    • Insert the plastic opening tool under the faceplate.
    • Separate the faceplate from main body by twisting the prying tool with some force.
    • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
    Добавить комментарий
  2. With the faceplate removed, simply peel off rubber key pad and remove.
    • With the faceplate removed, simply peel off rubber key pad and remove.
    • Locate and remove the six screws on the front of the phone using a T6 Torx.
      • All 6 screws are 6.9mm long.
    • After removing screws, lift the motherboard assembly straight off the cell phone body.
    • Be sure cell phone is off before you begin to disassemble the phone.
    • Press the button on the bottom of the back of the cell phone.
    • Slide rear panel down and remove it.
    • Using your fingernail, pry the back of the battery upwards and pull out.
    • With the LCD unit removed, gently press out the speaker with a non-metallic pointed object.
Заключение
Andres Echeverria
Участник с: 29.10.2010
4 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 20-8, Maness Fall 2010 Member of Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 членов
Автор 28 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 217
