Запчасти
Никакие детали не требуются.
Be sure cell phone is off before you begin to disassemble the phone.
  • Be sure cell phone is off before you begin to disassemble the phone.
  • Press the button on the bottom of the back of the cell phone.
  • Slide rear panel down and remove it.
Добавить комментарий
Using your fingernail, pry the back of the battery upwards and pull out.
  • Using your fingernail, pry the back of the battery upwards and pull out.
  • Insert the plastic opening tool under the faceplate.
  • Separate the faceplate from main body by twisting the prying tool with some force.
  • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  • With the faceplate removed, simply peel off rubber key pad and remove.
  • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
  • After removing screws, lift the motherboard assembly straight off the cell phone body.
  • Locate the two plastic LCD unit hooks.
  • Pry hooks outward.
  • Gently pull LCD unit away from the logic board.
    • Be careful not to damage the connection on the top, right hand side of the logic board.
  • With the LCD unit removed, gently press out the speaker with a non-metallic pointed object.
Заключение
Andres Echeverria
Участник с: 29.10.2010
4 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 20-8, Maness Fall 2010 Member of Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 членов
Автор 28 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 189
