Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
After removal, lower the metal sim card holder into its original position.
Insert the plastic opening tool into the crack between the front and back panels.
Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
Lift the bottom of the front cover away from the phone.
Continue lifting until the top of the front cover is fully removed from the phone.
3 участников успешно повторили данное руководство.
