Nokia 3300B Motherboard Replacement
Выберете то, что вам нужно
  1. Nokia 3300B Motherboard Replacement, Battery: шаг 1, изображение 1 из 2 Nokia 3300B Motherboard Replacement, Battery: шаг 1, изображение 2 из 2
    • Flip the Nokia 3300B over with the back-side facing towards you.
    • Gently press the button on the back of the battery cover to release the cover and slide up.
  2. Nokia 3300B Motherboard Replacement: шаг 2, изображение 1 из 2 Nokia 3300B Motherboard Replacement: шаг 2, изображение 2 из 2
    • Lift the battery out of the back of the phone.
    • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
  3. Nokia 3300B Motherboard Replacement, Keyboard: шаг 3, изображение 1 из 2 Nokia 3300B Motherboard Replacement, Keyboard: шаг 3, изображение 2 из 2
    • Gently push the blue tabs on the top of the phone out of their slots.
    • With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
    • Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
  4. Nokia 3300B Motherboard Replacement: шаг 4, изображение 1 из 1
    • With the screen still facing you, lift and remove the blue faceplate.
  5. Nokia 3300B Motherboard Replacement: шаг 5, изображение 1 из 1
    • Grab the sides of the keypad and lift each side up vertically, until the keypad is completely removed.
    • If you encounter resistance while removing the keypad, be sure to lift up evenly on both sides to ensure that the pins do not snap.
    • When replacing the keypad, make sure that the plastic pegs all enter their proper holes.
  6. Nokia 3300B Motherboard Replacement, Motherboard: шаг 6, изображение 1 из 2 Nokia 3300B Motherboard Replacement, Motherboard: шаг 6, изображение 2 из 2
    • Remove the six Torx T6 screws from the phone's front case.
  7. Nokia 3300B Motherboard Replacement: шаг 7, изображение 1 из 1
    • Pull up on the front case containing the screen to separate it from the rest of the phone.
    • Gently lift the main board out of the back case.
Заключение
3 участников успешно повторили данное руководство.
Jose Quezada
Участник с: 04/13/10
50 Репутация
1 руководство автора
Команда
Cal Poly, Team 18-65, Johann Spring 2010 Участник Cal Poly, Team 18-65, Johann Spring 2010
CPSU-JOHANN-S10S18G65
4 членов
Автор 9 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 2,878
