Nokia 6 Loudspeaker Replacement
Выберете то, что вам нужно
  1. Nokia 6 Loudspeaker Replacement, Display Assembly: шаг 1, изображение 1 из 3 Nokia 6 Loudspeaker Replacement, Display Assembly: шаг 1, изображение 2 из 3 Nokia 6 Loudspeaker Replacement, Display Assembly: шаг 1, изображение 3 из 3
    • Power off your Nokia 6 before beginning disassembly.
    • Insert the SIM card ejection tool into the hole on the left side of the phone.
    • Remove the SIM card and microSD card.
  2. Nokia 6 Loudspeaker Replacement: шаг 2, изображение 1 из 1
    • If your display glass is cracked, take precaution by taping over the display to prevent further breakage and harm.
    • Lay overlapping strips of clear packing tape over the Nokia 6's display until the whole screen is covered.
  3. Nokia 6 Loudspeaker Replacement: шаг 3, изображение 1 из 1
    • To soften the adhesive, use a heat gun and heat one edge of the phone for five minutes.
    • To use the heat gun, plug it into an outlet.
    • When the heat gun is plugged in, the heat gun automatically turns on and will start blowing hot air.
  4. Nokia 6 Loudspeaker Replacement: шаг 4, изображение 1 из 1
    • Take a Jimmy and slide it under the glass after the adhesive has been softened.
    • Place a pick under the glass after lifting with the pry tool so that the screen won't re-adhere to the frame again.
    • Make sure to not touch the LCD edge underneath the glass layer with the metal pry tool or the cards. This can damage the ribbon cables underneath and compromise the structural integrity of the phone itself.
    • The corners of the screen are the most fragile part of the screen. Make sure that the entire edge of the screen is dislodged from the frame before prying at the corners.
  5. Nokia 6 Loudspeaker Replacement: шаг 5, изображение 1 из 1
    • Lift the screen off of the phone.
  6. Nokia 6 Loudspeaker Replacement: шаг 6, изображение 1 из 2 Nokia 6 Loudspeaker Replacement: шаг 6, изображение 2 из 2
    • Use a Phillips #000 screwdriver to remove the 1 mm x 1.4 mm screw holding down the metal bracket over the screen ribbon connector.
  7. Nokia 6 Loudspeaker Replacement: шаг 7, изображение 1 из 1
    • Remove the metal bracket with a tweezer.
  8. Nokia 6 Loudspeaker Replacement: шаг 8, изображение 1 из 1
    • Use a spudger to disconnect the screen ribbon connector and free the display assembly.
    • The corners and edge of the LCD are fragile. Be careful attaching it to the back of the phone.
    • Carefully remove the screen from the device.
  9. Nokia 6 Loudspeaker Replacement, Home Button Assembly: шаг 9, изображение 1 из 1
    • Disconnect the battery connector with a spudger.
  10. Nokia 6 Loudspeaker Replacement: шаг 10, изображение 1 из 2 Nokia 6 Loudspeaker Replacement: шаг 10, изображение 2 из 2
    • Use a Phillips #00 screwdriver to remove the 1.2 mm x 2.2 mm screw in the upper hand corner of the phone.
    • Use tweezers to remove the bracket.
  11. Nokia 6 Loudspeaker Replacement: шаг 11, изображение 1 из 2 Nokia 6 Loudspeaker Replacement: шаг 11, изображение 2 из 2
    • Detach the cable with the black nylon spudger.
    • Detach the home button and remove it from the device.
  12. Nokia 6 Loudspeaker Replacement, Midframe: шаг 12, изображение 1 из 1
    • Remove 18 screws.
    • There is one 1 mm x 1.4 mm screw that needs to be removed by a Phillips #000 screwdriver.
    • One of the screws is 1.2 mm x 4.2 mm and will be removed by a Phillips #00.
    • The remaining 16 screws can be removed by the Phillips #00 screwdriver and are 1.2 mm x 2.2 mm.
  13. Nokia 6 Loudspeaker Replacement: шаг 13, изображение 1 из 2 Nokia 6 Loudspeaker Replacement: шаг 13, изображение 2 из 2
    • Decouple the midframe with the spudger and remove the midframe from the device.
  14. Nokia 6 Loudspeaker Replacement, Motherboard: шаг 14, изображение 1 из 2 Nokia 6 Loudspeaker Replacement, Motherboard: шаг 14, изображение 2 из 2
    • Remove the bracket with tweezers.
  15. Nokia 6 Loudspeaker Replacement: шаг 15, изображение 1 из 3 Nokia 6 Loudspeaker Replacement: шаг 15, изображение 2 из 3 Nokia 6 Loudspeaker Replacement: шаг 15, изображение 3 из 3
    • Detach the two cables with the spudger.
    • Detach the cable with a pair of tweezers.
    • Be careful when detaching the cables, make sure to not completely remove the cables from the phone!
  16. Nokia 6 Loudspeaker Replacement: шаг 16, изображение 1 из 1
    • Remove six screws.
    • Two of these screws are 1.0 mm x 1.4 mm and need to be removed by a Phillips #000 screwdriver.
    • The remaining four screws are 1.2 mm x 2.2 mm and are removed by a Phillips #00 screwdriver.
  17. Nokia 6 Loudspeaker Replacement: шаг 17, изображение 1 из 2 Nokia 6 Loudspeaker Replacement: шаг 17, изображение 2 из 2
    • Remove the motherboard from the Nokia 6 with the spudger.
    • Be careful because the motherboard is fragile. Wiggle it gently to remove it.
  18. Nokia 6 Loudspeaker Replacement, Microphone: шаг 18, изображение 1 из 1
    • With tweezers, lift the wire by the microUSB port and the microphone unit.
  19. Nokia 6 Loudspeaker Replacement: шаг 19, изображение 1 из 1
    • Remove three screws.
    • Two of these are 1 mm x 1.4 mm and can be removed by a Phillips #000.
    • One of the screws is 1.2 mm x 2.2 mm and can be removed by a Phillips #00.
  20. Nokia 6 Loudspeaker Replacement: шаг 20, изображение 1 из 2 Nokia 6 Loudspeaker Replacement: шаг 20, изображение 2 из 2
    • Remove the microUSB port and the microphone by lifting the unit with a spudger.
    • Lift the black strip gently with the spudger, make sure not to rip it.
  21. Nokia 6 Loudspeaker Replacement, Loudspeaker: шаг 21, изображение 1 из 2 Nokia 6 Loudspeaker Replacement, Loudspeaker: шаг 21, изображение 2 из 2
    • Use a spudger to remove the loudspeaker from the phone.
Заключение
Еще один человек закончил это руководство.
Chrissy Robins
Участник с: 04/15/19
1 510 Репутация
Автор 10 руководств
Команда
Cal Poly, Team S9-G15, Maness Spring 2019 Участник Cal Poly, Team S9-G15, Maness Spring 2019
CPSU-MANESS-S19S9G15
4 членов
Автор 14 руководств
Один комментарий
Great article and just one question. “To reassemble your device, follow these instructions in reverse order.” That’s ok until the screen needs to be glued back so advice on doing that would be appreciated.
murraysnudge - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 8
За всё время: 1,297
