Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Replacing the glass/front cover of the phone.
Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
Lift out battery and remove.
Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen.
After removing the top cover, turn the phone over so the screen is facing upwards.
