Введение
Replacing LCD Screen.
Выберете то, что вам нужно
Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
Lift out battery and remove.
Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
After removing the top cover, turn the phone over so the screen is facing upwards.
Use your fingers to slowly lift the screen back towards the bottom of the phone using the arrows found at the top of the phone.
Remove the six screws found along the frame of the phone with a T6 Torx screwdriver and put them to the side.
2 участников успешно повторили данное руководство.
