Nokia 6085h Microphone Replacement
Выберете то, что вам нужно
  1. Nokia 6085h Microphone Replacement, Battery: шаг 1, изображение 1 из 1
    • Flip over the phone so that the back is facing up.
    • Pressing your thumb against the back cover, slide the cover off of the phone.
  2. Nokia 6085h Microphone Replacement: шаг 2, изображение 1 из 1
    • Remove the phone's battery.
  3. Nokia 6085h Microphone Replacement, Motherboard: шаг 3, изображение 1 из 2 Nokia 6085h Microphone Replacement, Motherboard: шаг 3, изображение 2 из 2
    • Use the iFixit opening tool to pry out the two tabs at the top corners of the battery compartment.
  4. Nokia 6085h Microphone Replacement: шаг 4, изображение 1 из 1
    • Gently pull off the hinge cap from the top of the phone by hand.
  5. Nokia 6085h Microphone Replacement: шаг 5, изображение 1 из 1
    • Use a T6 Torx screwdriver to remove the four 7.6 mm screws at the corners of the battery compartment.
  6. Nokia 6085h Microphone Replacement: шаг 6, изображение 1 из 2 Nokia 6085h Microphone Replacement: шаг 6, изображение 2 из 2
    • Open the phone and turn it on its side. You will see a seam around the Nokia’s side.
    • Use the iFixit opening tool to run along this seam to pop the clips holding the casing to the frame.
  7. Nokia 6085h Microphone Replacement: шаг 7, изображение 1 из 1
    • Use your hand to gently pull off the back panel from the bottom half of the phone.
  8. Nokia 6085h Microphone Replacement: шаг 8, изображение 1 из 1
    • Close the phone and place it on a flat surface.
    • Use the plastic opening tool or your finger to lift up the motherboard from the bottom casing.
    • Be careful when pulling up the board; there is still a ribbon cable attached to the back of the board.
  9. Nokia 6085h Microphone Replacement: шаг 9, изображение 1 из 1
    • Find the underside of the motherboard and locate the ribbon cable that attaches the board to the rest of the phone. Use the plastic opening tool to slowly detach the ribbon cable connector, then pull the motherboard away from the frame.
  10. Nokia 6085h Microphone Replacement, Keypad: шаг 10, изображение 1 из 1
    • Pry the keypad out with the plastic opening tool once the motherboard is moved out of the way.
  11. Nokia 6085h Microphone Replacement, Microphone: шаг 11, изображение 1 из 1
    • Locate the small speaker module on the back of the separated battery compartment in the lower left hand corner.
  12. Nokia 6085h Microphone Replacement: шаг 12, изображение 1 из 1
    • Use the plastic opening tool to pry out the microphone from the bottom of the compartment.
Заключение
Andrew
Участник с: 10/04/10
397 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 4-46, Amido Fall 2010 Участник Cal Poly, Team 4-46, Amido Fall 2010
CPSU-AMIDO-F10S4G46
4 членов
Автор 14 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 14
За всё время: 353
