Введение
This guide will show you how to remove the Speaker from the phone.
Запчасти
No parts specified.
  1. Press the button to remove the back cover. Pull the cover downward and lift it off while still pressing the button.
    • Press the button to remove the back cover.
    • Pull the cover downward and lift it off while still pressing the button.
  2. Lift the battery out of the phone by pushing down from the top and pulling out
    • Lift the battery out of the phone by pushing down from the top and pulling out
  3. Grip the front cover from the bottom.
    • Grip the front cover from the bottom.
  4. Lift the front cover off.
    • Lift the front cover off.
  5. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  6. Locate 6 screws on front of assembly and unscrew them using a T6 torx screwdriver.
    • Locate 6 screws on front of assembly and unscrew them using a T6 torx screwdriver.
  7. Insert spudger along edge of assembly and gently lift assembly away from case
    • Insert spudger along edge of assembly and gently lift assembly away from case
  8. Remove assembly from phone
    • Remove assembly from phone
  9. Flip assembly over
    • Flip assembly over
  10. Locate speaker on the back of the assembly.
    • Locate speaker on the back of the assembly.
  11. Insert spudger under upper left side of speaker and gently lift to remove
    • Insert spudger under upper left side of speaker and gently lift to remove
  12. Remove speaker.
    • Remove speaker.
Заключение
Colby Leslie
Участник с: 05.10.2010
1 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 22-3, Maness Fall 2010 Member of Cal Poly, Team 22-3, Maness Fall 2010
CPSU-MANESS-F10S22G3
4 членов
Автор 9 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 703
