Введение
How to remove the keypad.
Выберете то, что вам нужно
Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
