Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Start by removing the face plate of the phone with a plastic tool.
Once plastic tool is wedged into the side of the phone, twist and leverage the face plate off.
Once the face plate is off, you will have exposed the keypad.
Simply remove the keypad from on top of the phone, and place it off to the side, leaving just the phone itself remaining
Taking a very small screwdriver, carefully unscrew the six screws attaching the top layer of the screen from the body of the phone.
Once the six screws are removed, you may take off the screen section of the phone, exposing the inner workings of the cell phone.
Separate the Logic Board from the main body of the device.
Insert in the replacement Logic Board, setting the Logic Board carefully back into place.
Set the screen carefully over the body of the phone, avoiding any sliding on the Logic board
Replace screws in the corresponding slots, tightening them till they are not loose.
Lastly, you can place the cover onto the phone. You will know when it is in place if you hear a click after placing it in.
