Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The circuit board processes all the information the phone uses. Removing the circuit board allows access to several underlying components.
Запчасти
Детали не указаны.
  1. Locate the small button on the top of the phone. Depress the button. With your other hand, pull the front cover away from the phone.
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
  2. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  3. Remove all six 5.3 mm long T6 screws. Remove the circuit board/faceplate sub-assembly from the back of the phone. Take care to place screws in a safe location.
    • Remove all six 5.3 mm long T6 screws.
    • Remove the circuit board/faceplate sub-assembly from the back of the phone.
    • Take care to place screws in a safe location.
  4. Using your fingers, pull the small plastic tab away from the circuit board/faceplate sub-assembly. Rotate the faceplate away from the circuit board. Gently remove the faceplate from the circuit board, taking care to not break the small plastic tab on the other side of the sub-assembly.
    • Using your fingers, pull the small plastic tab away from the circuit board/faceplate sub-assembly.
    • Rotate the faceplate away from the circuit board.
    • Gently remove the faceplate from the circuit board, taking care to not break the small plastic tab on the other side of the sub-assembly.
Заключение
Parker Niebauer
Участник с: 22.10.2012
1 Репутация
Автор 6 руководств
Команда
Clemson, Team 15-3, Benson Fall 2012 Участник Clemson, Team 15-3, Benson Fall 2012
CLEM-BENSON-F12S15G3
3 членов
Автор 21 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 362
