Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide shows you how to remove or install the SIM card in case of needed replacement.
Запчасти
Детали не указаны.
  1. Locate the button on the bottom of the back cover.
    • Locate the button on the bottom of the back cover.
  2. Depress the button with your finger. While the button is depressed, slide the back cover off of the phone. While the button is depressed, slide the back cover off of the phone.
    • Depress the button with your finger.
    • While the button is depressed, slide the back cover off of the phone.
  3. Place the phone so that the battery is face up. Insert a screwdriver or spudger into the crevice above the battery.
    • Place the phone so that the battery is face up.
    • Insert a screwdriver or spudger into the crevice above the battery.
  4. Use a screwdriver or spudger to lift the battery out of the casing. Use a screwdriver or spudger to lift the battery out of the casing.
    • Use a screwdriver or spudger to lift the battery out of the casing.
  5. Place the spudger under the plastic cover and lightly lift. Insert the SIM Card under the plastic cover and close.
    • Place the spudger under the plastic cover and lightly lift.
    • Insert the SIM Card under the plastic cover and close.
Заключение
Clinton
Участник с: 22.10.2012
57 Репутация
Автор 7 руководств
Команда
Clemson, Team 14-5, Benson Fall 2012 Участник Clemson, Team 14-5, Benson Fall 2012
CLEM-BENSON-F12S14G5
3 членов
Автор 16 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 165
