Запчасти
Никакие детали не требуются.
  1. Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Remove the back cover to expose the battery.
    • Remove the back cover to expose the battery.
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out.
    • Locate the plastic latches on the left and right sides of the phone.
    • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • CAUTION! Some force is required.
    • Remove the faceplate with the number pad attached.
    • Turn the faceplate so the number pad faces downward.
    • Lift the number pad out of the faceplate.
    • Locate the six screws positions along the edges of the motherboard.
    • Unscrew the six screws using the Torx 5 screwdriver (see Introduction for description of a Torx 5 screwdriver).
    • CAUTION! Place the screws in a secure location.
    • Locate the orange ribbon tape connecting the metal display plate to the motherboard.
    • Lift the black latch attaching the tape to the motherboard.
    • Gently pull the tape out of the latch slot to remove the metal display.
    • Using the plastic opening tool, gently pry off the motherboard from the plastic shell.
    • CAUTION! When pulling the motherboard out, be careful not to damage the battery under the lower left hand corner of the motherboard.
    • Gently pull the orange ribbon tape up to remove the display.
    • Replace display screen.
    • Follow the instructions in reverse order to reassemble the phone.
Заключение
2 участников успешно повторили данное руководство.
Ian VanZandt
Участник с: 14.02.2012
600 Репутация
Автор 5 руководств
Команда
James Madison, Team 3-1, Klein Spring 2012 Member of James Madison, Team 3-1, Klein Spring 2012
JMU-KLEIN-S12S3G1
3 членов
Автор 9 руководств
Комментариев: 2
Pretty accurate, nice guide! Easily repaired and it works!
Dominik Fryč - Ответить
Perfect guide! But Where can i get original components??
Navin Singh - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 5
За всё время: 725
