Введение
Use this guide to replace the Nokia E61i screen.
Запчасти
To access the battery you must remove the back cover. Press the tab on the bottom of the cover in so that the back cover plate can slide over it.
Now slide the back cover off of the phone.
Once the backplate is removed, look to the bottom-left corner of the phone where there is a spot to remove the battery.
Remove the four screws securing the front cover to the rest of the phone using a T7 screwdriver.
After the screws have been removed, there is nothing else securing the front cover to the rest of the phone. Simply remove the cover by pulling it up and off.
After taking off the casing and keyboard, remove the screws holding the screen in place. Use a T-6 for the screws in the middle of the red circles, and use a T-5 for the screw in the middle of the red square.
Lift the ribbon off of the contact with the motherboard.
When reassembling, firmly press the contacts into place to connect the ribbon and the motherboard.
Once the screws are out, gently pull the screen off of the phone.
Finally, pull the silver case off to completely free the cracked or damaged screen.
3 участников успешно повторили данное руководство.
