Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Use this guide to replace the Nokia E61i screen.
  1. To access the battery you must remove the back cover. Press the tab on the bottom of the cover in so that the back cover plate can slide over it. Now slide the back cover off of the phone.
    • To access the battery you must remove the back cover. Press the tab on the bottom of the cover in so that the back cover plate can slide over it.
    • Now slide the back cover off of the phone.
  2. Once the backplate is removed, look to the bottom-left corner of the phone where there is a spot to remove the battery.
    • Once the backplate is removed, look to the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Use your finger to lift the battery out.
    • Use your finger to lift the battery out.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Remove the four screws securing the front cover to the rest of the phone using a T7 screwdriver. Remove the four screws securing the front cover to the rest of the phone using a T7 screwdriver.
    • Remove the four screws securing the front cover to the rest of the phone using a T7 screwdriver.
  5. After the screws have been removed, there is nothing else securing the front cover to the rest of the phone. Simply remove the cover by pulling it up and off.
    • After the screws have been removed, there is nothing else securing the front cover to the rest of the phone. Simply remove the cover by pulling it up and off.
  6. After taking off the casing and keyboard, remove the screws holding the screen in place. Use a T-6 for the screws in the middle of the red circles, and use a T-5 for the screw in the middle of the red square. Lift the ribbon off of the contact with the motherboard.
    • After taking off the casing and keyboard, remove the screws holding the screen in place. Use a T-6 for the screws in the middle of the red circles, and use a T-5 for the screw in the middle of the red square.
    • Lift the ribbon off of the contact with the motherboard.
    • When reassembling, firmly press the contacts into place to connect the ribbon and the motherboard.
  7. Once the screws are out, gently pull the screen off of the phone. Be sure not to rip the sticker (in the blue square) that attaches the display and the motherboard.
    • Once the screws are out, gently pull the screen off of the phone.
    • Be sure not to rip the sticker (in the blue square) that attaches the display and the motherboard.
    • Finally, pull the silver case off to completely free the cracked or damaged screen.
Заключение
3 участников успешно повторили данное руководство.
Christopher Patton
Участник с: 07.04.2011
208 Репутация
Автор 12 руководств
Команда
Cal Poly, Team 9-63, Walters Spring 2011 Участник Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 членов
Автор 12 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 8
За всё время: 3,383
