Введение
This repair guide shows how to remove the battery from the Nokia E90 cellphone. It involves three simple steps and there are no tools required.
In order to remove the back cover, you must press the indicated button.
With the button pressed, apply light pressure and slide the back cover off.
This will allow you to access the battery
In order to remove the battery, pull it out from the same side that the rubber button is on.
To reassemble the back cover, simply slide it back on.
Еще один человек закончил это руководство.
