Nokia E90 Front Cover Replacement
Выберете то, что вам нужно
  1. Nokia E90 Front Cover Replacement, Front Cover: шаг 1, изображение 1 из 1
    • Start with the phone in the flipped open position.
    • You must remove the sticker in the center, below the screen to reveal the center screw.
    • Use a T5 screwdriver to remove all three screws, loosening the front screen.
  2. Nokia E90 Front Cover Replacement: шаг 2, изображение 1 из 2 Nokia E90 Front Cover Replacement: шаг 2, изображение 2 из 2
    • Flip the phone to the closed position and turn to the front screen.
    • The front cover will now be loose enough for you to remove by grabbing the edges and lightly pulling the cover off.
Заключение
Еще один человек закончил это руководство.
Cameron Weinberg
Участник с: 04/12/11
540 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 18-21, Garner Spring 2011 Участник Cal Poly, Team 18-21, Garner Spring 2011
CPSU-GARNER-S11S18G21
3 членов
Автор 8 руководств
2 Комментариев
I have a n90 done which will not switch on. I have changed the battery and still nothing.pressing the top power button but nothing.trying to get old pics off the phone any help?
Smith - Ответить
Hello Mr Smith. Have you tried to recharge the battery as it is in the phone in question? Recharge the battery while it is in the phone first, IF the phone in question still does not boot up then get another battery from ebay. I have a similar E90 as yours and the battery did go flat in the end, like all batteries, I just got a new battery and then recharged the battery while it is in the phone. Good luck.
Keith N Searle -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 4,895
