Введение
If your front screen has stopped working and you need a new one, this guide will show you how to access the front screen.
Выберете то, что вам нужно
Start with the phone in the flipped open position.
You must remove the sticker in the center, below the screen to reveal the center screw.
Use a T5 screwdriver to remove all three screws, loosening the front screen.
Flip the phone to the closed position and turn to the front screen.
The front cover will now be loose enough for you to remove by grabbing the edges and lightly pulling the cover off.
With the front cover off, the screen and keypad should be loose.
Using a plastic opening tool pry up the cable connecting the LCD screen to the rest of the phone.
With the cable disconnected, the screen should be free for removal or replacement.
In order to reassemble the front screen or install a new screen, follow the steps provided, in reverse order.
Еще один человек закончил это руководство.
