Введение
If the Touchscreen / Glass of your phone is broken, this guide will help you to disassemble the phone and replace the Digitizer.
__________________________________________ Video manual: __________________________________________
Выберете то, что вам нужно
Видео обзор
Switch off the phone and remove the battery.
Remove 8x Torx T5 screws.
With a plastic tool, start with separating the middle frame from the down side.
The Loudspeaker is on the middle frame.
Disconnect the LCD Display flex cable.
Disconnect the Touch screen flex cable.
The Logic board is held by 2x locking clips at the bottom side.
Release it and gently remove it from the front frame.
Put tape on the glass to not scatter pieces.
Worm the glass to melt the adhesive.
Use plastic tools to separate the touchscreen from the frame.
After separating, clean up the sticker that remains on the borders.
New line.Install the new touchscreen and reassemble the device.
4 человек успешно провели ремонт по этому руководству.
