Введение
With this guide we will help you, if you want to disassemble the phone and replace the Digitizer / Glass or the LCD Display. Also this guide is useful for replacing Loudspeaker, Earpiece, Front camera, etc.
Before ordering the new Touch screen check the revision (you can see it on the digitizer flex cable, near to the connector).
__________________________ Video manual: __________________________
Выберете то, что вам нужно
Видео обзор
Switch off the phone, remove the battery and SIM (Memory) card.
The lower back cover is held by 3x T4 Torx screws.
Loudspeaker
Touch screen flex cable connector
LCD Display flex cable connector
If you want to replace the Digitizer, let's test the spare part first.
Another three screws hold the Upper Back Cover.
Disconnect the Touch screen and the Digitizer flex cables.
If you have not yet disconnected the Digitizer and the Touch screen flex cables, do it now.
The Logic Board is held to the Middle frame by two plastic clips.
Front Camera and Proximity & Light sensor module
Earpiece
Remove them one by one.
The Midle frame is held by 6x locking clips, three on each side. Release them and remove the Middle frame.
Now gently remove the LCD Display.
If you have a broken LCD, replace it and reassemble the phone.
We will continue with removing the Touch screen Glass.
Put a scotch tape to prevent the glass from scattering.
With a hot air warm the glass to soften the adhesive.
Start with separating at the middle, where the bonded area is smaller.
Clean the remnants of the old adhesive tape.
If the spare parts come without adhesive tape, you must put by himself.
Prepare the new digitizer glass and install it.
Reassemble the device.
13 участников успешно повторили данное руководство.
2 Комментариев
i am purchase urgent
