Введение
How to disassemble Nokia Lumia 625 to change / replace the battery.
Инструменты
Запчасти
Детали не указаны.
Видео обзор
Turn off the phone and remove the back cover.
Remove any installed SIM or memory card.
Use a screwdriver Torx T5 and remove the 8x black screws.
At the top and bottom of the phone you'll see two grooves.
Use a plastic tool and start the separating the rear bezel from here.
Disconnect the battery connector.
Use a plastic tool and unstuck the battery.
Look at the picture to see where is the battery adhesive sticker.
11 участников успешно повторили данное руководство.
Комментариев: 2
Simple
Très compréhensible
Efficace
Bravo
