Введение
The front camera is an integral part of the Nokia Lumia 900. Because it is a small and delicate component, this guide will show how to remove it carefully and properly.
Выберете то, что вам нужно
Insert the pointed end of the spudger into the sim card port indicated by the picture. Then proceed to remove the sim card port entirely.
Separate the screen from the motherboard by prying it open with the spudger along with pulling upwards with the suction cup.
Gently pull apart the screen from the motherboard, with only the ribbons connected from the motherboard to the screen.
Disconnect the No-fuss cables from the motherboard by gently prying them up using the flat end of the black stick spudger. Make sure not to bend or crease the cable.
Remove the screen.
Use the iFixit iOpener or another heat source to gently heat the top left corner until the adhesive under the camera softens.
Use the plastic opening tools to carefully lift the front camera from the motherboard.
