Выберете то, что вам нужно
Remove the sim card holder by inserting tweezers into the hole. Push down and the holder will spring back up.
Pull out the holder until it is completely separate.
Slide a plastic opening tool under the back cover.
Slide the tool around the outsides of the cover to fully dislodge the pins holding the cover to the phone.
Remove the 3 screws using the T7 Torx screwdriver.
Unclip the black tab connector.
Unclip the two orange tabs.
Remove the four silver screws using the T5 Torx screwdriver.
Remove the motherboard by sliding tweezers between it and the back of the screen. Lift up.
3 участников успешно повторили данное руководство.
