Введение
This guide will show you how to remove the battery in your Nokia Lumia 928. It has two prerequisite guides that will first teach you how to remove the back cover, then the motherboard, which will allow you to remove the battery. It involves removing some screws, and prying the battery off the motherboard that is held in with glue.
Выберете то, что вам нужно
Power down the phone.
There is a screw located inside the 3.5mm headphone jack that needs to be loosened. Use a Torx T5 screwdriver for this.
Remove the sim card tray on the top of the phone.
Remove the 4.5 mm Torx T5 screw highlighted with a red circle in the picture. (Note: all screws that you will remove in the phone will be the same)
Using the plastic opening tools, you can start to release the plastic clips around the phone. Start in the top left corner, work your way down the left side. Then do the top and bottom of the phone, and finally the right side.
Once all the clips are released, remove the back cover of the phone.
Remove all 10 T5 screws on the motherboard. All screws are 4.5 mm Torx T5 screws.
Remove the ribbon connector with a highlighted with a red circle with the plastic opening tool.
The ribbon connector highlighted in yellow has a zero insertion force connector. This has a black flap on the end that needs to be flipped up before the ribbon cable can be pulled out.
Remove USB port cover using the plastic opening tool, or your hand. It can be removed easily.
Pull up the left side of the motherboard.
You have now removed the motherboard from the display assembly and the back cover.
Use the plastic opening tool to pry the battery away from the motherboard.
Now that the battery is separated from the motherboard, it is time to remove it. First you will need to lift the connector for the battery's ribbon cable.
Once the connector has been freed, you can start to pull the battery away from the motherboard.
Once you feed the ribbon cable out through the hole in the motherboard, the battery can be removed from the motherboard.
