Nokia Lumia 928 Front Facing Camera Replacement
Выберете то, что вам нужно
  1. Nokia Lumia 928 Front Facing Camera Replacement, Back Cover: шаг 1, изображение 1 из 2 Nokia Lumia 928 Front Facing Camera Replacement, Back Cover: шаг 1, изображение 2 из 2
    • Power down the phone.
    • There is a screw located inside the 3.5mm headphone jack that needs to be loosened. Use a Torx T5 screwdriver for this.
    • The screw does not come out. Once loosened, It will unlock the lock bar inside the phone. You will break it if you do not complete this step properly.
    • Remove the sim card tray on the top of the phone.
    • Remove the 4.5 mm Torx T5 screw highlighted with a red circle in the picture. (Note: all screws that you will remove in the phone will be the same)
    • There is a sticker located on the screw that needs to be peeled off. This voids your warranty.
  2. Nokia Lumia 928 Front Facing Camera Replacement: шаг 2, изображение 1 из 3 Nokia Lumia 928 Front Facing Camera Replacement: шаг 2, изображение 2 из 3 Nokia Lumia 928 Front Facing Camera Replacement: шаг 2, изображение 3 из 3
    • Using the plastic opening tools, you can start to release the plastic clips around the phone. Start in the top left corner, work your way down the left side. Then do the top and bottom of the phone, and finally the right side.
    • It can be useful to flip the plastic opening tool upside down in certain areas of the phone to make releasing the plastic clips easier.
    • Once all the clips are released, remove the back cover of the phone.
  3. Nokia Lumia 928 Front Facing Camera Replacement, Front Facing Camera: шаг 3, изображение 1 из 1
    • Remove both ends of the ribbon connector using a plastic opening tool.
    • The end highlighted with an orange circle in the picture must slide out towards the edge of the phone.
    • Be very careful with the ribbon connectors as they can easily be broken.
  4. Nokia Lumia 928 Front Facing Camera Replacement: шаг 4, изображение 1 из 3 Nokia Lumia 928 Front Facing Camera Replacement: шаг 4, изображение 2 из 3 Nokia Lumia 928 Front Facing Camera Replacement: шаг 4, изображение 3 из 3
    • Remove the ribbon connector for the front facing camera using the plastic opening tool. Once you have done this, you can lift out the front facing camera with the ribbon connector.
    • The ribbon connector is held down with some glue, so peel it off slowly to avoid damaging it.
    • You have now successfully removed the front facing camera.
Заключение
Curtis Dawe
Участник с: 03/04/16
461 Репутация
Автор 4 руководств
Команда
UMass Dartmouth, Team 6-8, Bhusal Spring 2016 Участник UMass Dartmouth, Team 6-8, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G8
4 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 8
За всё время: 178
