Введение
This guide will show you how to replace the front facing camera on your device. It contains one prerequisite guide that will teach you how to remove the back cover, which will then allow you to remove the front facing camera. It involves removing 1 screw and some ribbon connectors.
Выберете то, что вам нужно
Power down the phone.
There is a screw located inside the 3.5mm headphone jack that needs to be loosened. Use a Torx T5 screwdriver for this.
Remove the sim card tray on the top of the phone.
Remove the 4.5 mm Torx T5 screw highlighted with a red circle in the picture. (Note: all screws that you will remove in the phone will be the same)
Using the plastic opening tools, you can start to release the plastic clips around the phone. Start in the top left corner, work your way down the left side. Then do the top and bottom of the phone, and finally the right side.
Once all the clips are released, remove the back cover of the phone.
Remove both ends of the ribbon connector using a plastic opening tool.
The end highlighted with an orange circle in the picture must slide out towards the edge of the phone.
Remove the ribbon connector for the front facing camera using the plastic opening tool. Once you have done this, you can lift out the front facing camera with the ribbon connector.
You have now successfully removed the front facing camera.
