Выберете то, что вам нужно
Orient the phone as shown.
Press the button with the plastic opening tool and slide the back case downward relative to the phone.
Insert the plastic opening tool into the marked space.
Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
Insert the plastic opening tool in the marked areas in between the front and back covers.
Pry each corner with the plastic opening tool until the front case completely detaches.
Separate the front panel from the back by lifting the bottom of the front panel at a 45 degree angle.
Remove the front panel by lifting the panel away from the phone at a 45 degree angle.
Locate the rear circuit board by flipping over the front panel.
Locate the rear camera and by using the plastic opening tool, gently lift the camera out of the slot.
5 участников успешно повторили данное руководство.
Один комментарий
mon nokia n70 est mal camera alors quest -ce qu*on va faire
