Введение
If you have problems with the OS, forgotten screen lock or you want to erase all your personal data, you can do Factory / Hard Reset.
Nokia Lumia - Icon, 520, 525, 530, 620, 625, 630, 635, 720, 730, 820, 830, 920, 925, 928, 930, 1020, 1320, 1520,
Microsoft Lumia - 430, 435, 532, 535, 540, 550, 640, 950, 1030,
HTC Windows Phone - 8S, 8X
Видео обзор
Turn off the phone.
Press and hold the Volume Down and the Power buttons.
When you feel a vibration, release only the Power button,
or,
press and hold the Volume down button and connect the charger.
You will see an exclamation mark.
Press the keys in this order:
Volume Up
Volume Down
Power
Volume Down
The phone will reset and restart. This may take a few minutes.
Did you do it successfully?
This does work.
It worked. Thanks!
It doesn't work for mine.
Thanks...it worked
Thanks. Perfectly well!! God Bless.
Thanks. Perfectly well. God bless.
Can't work on lumia 625
Worked for me too but took a little longer than I expected
Thanks alot
It has worked out successfully
Thank it worked !
It worked ! Thanks
power button is broken of Nokia Lumia 1320 is there any other way to do it
It does not work on my phone
GOLD - 2 Thumbs up
Wow it really worked great! Easy as 123 Thanks
It worked,am so happy
Thank you so much. Xmas,. Soon.
If it doesn't work, try the procedure again.
48 участников успешно повторили данное руководство.
22 Комментариев
dint work still asking for password to unlock the phone
i just got my cell second hand i found it on the skytrain it says no sim but its locked how can i us this phone then i need hrlp
Thanks It worked
It worked....yay
It was excellent but I lost all my files so how do I retrieve my file back
Worked great!
It worked perfectly great thanks a lot I'm glad it helped me out
did not work asking reset protection key microsoft lumia640
my phone hard reaset after restarting ask reset protection key
How to set to my website?
Thank You Sir Great
did not work for my nokia carl zeiss tessar 2.2 28
how can i get past reset protection code if i dont know it stuck after reset
Still did not work
!&&* Yeh!!! Cheers 4 that. Spot on worked 1st time.
It did not work with the volume down and start button method. But it did work when I tried with the volume down and connect the Charger method. Thanks!
When a factory reset my phone. Now it's calling for a? Recovery key And I can't get into my phone. What do I do?
It says fastboot mode
Estou precisando de ajuda para formatar Nokia Lumia
Nokia Lumia 1230 eu acho que esse é o modelo.
Nokia Lumia 1230 I think this is the model.
Dont get exclimation point only nokia label looping
aleximarymurphy - Ответить
The Gear start turning and then just stop screen goes black then goes back to lock screen
Phillip Mason - Ответить
