Nokia X Headphone Jack Replacement
Выберете то, что вам нужно
  1. Nokia X Headphone Jack Replacement, Battery: шаг 1, изображение 1 из 1
    • The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
  2. Nokia X Headphone Jack Replacement: шаг 2, изображение 1 из 1
    • To remove the battery, simply use your finger to pry the battery out of its slot.
  3. Nokia X Headphone Jack Replacement: шаг 3, изображение 1 из 1
    • Inserting a new battery is as simple as lining up the gold connectors and sliding the battery in text-side down.
  4. Nokia X Headphone Jack Replacement, Display Assembly: шаг 4, изображение 1 из 2 Nokia X Headphone Jack Replacement, Display Assembly: шаг 4, изображение 2 из 2
    • Remove the four 5.33mm T5 Torx screws which are located in the corners of the phone.
    • Remove the seven 4.00mm T5 Torx screws that line the phone between the corners.
  5. Nokia X Headphone Jack Replacement: шаг 5, изображение 1 из 2 Nokia X Headphone Jack Replacement: шаг 5, изображение 2 из 2
    • To remove the screen from the motherboard, you will need to apply some force until you feel it snap off. If the connectors unhook themselves, don't worry.
  6. Nokia X Headphone Jack Replacement: шаг 6, изображение 1 из 1
    • If the connectors are still attached, simply unhook them by lifting the top of the connector with your finger.
  7. Nokia X Headphone Jack Replacement, Headphone Jack: шаг 7, изображение 1 из 2 Nokia X Headphone Jack Replacement, Headphone Jack: шаг 7, изображение 2 из 2
    • Using the flat end of the spudger tool, unhook the two connectors connecting the audio jack to the motherboard.
    • The top connecter is attached via an adhesive as well, it will require a little bit of force to remove it.
  8. Nokia X Headphone Jack Replacement: шаг 8, изображение 1 из 3 Nokia X Headphone Jack Replacement: шаг 8, изображение 2 из 3 Nokia X Headphone Jack Replacement: шаг 8, изображение 3 из 3
    • Gently insert the pointed end of the spudger tool into the audio jack and lightly press upwards until the jack snaps loose.
    • It will take a bit of force to disconnect the biggest circuit from the motherboard as it is attached via an adhesive.
Заключение
11 участников успешно повторили данное руководство.
Avery Dorsey
Участник с: 01/21/15
1 894 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 6-1, Brown Winter 2015 Участник USF Tampa, Team 6-1, Brown Winter 2015
USFT-BROWN-W15S6G1
3 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 3,349
