Введение
Is your Nokia X unable to connect to a USB charger? This guide will shows how to replace a faulty USB port.
Выберете то, что вам нужно
Remove the back cover of the device by applying light pressure toward the outer rim and display.
Remove 7 (size 4 M1 4*3.5) and 4(size 6 M2 6*4.5) screws using P5 hex screwdriver.
The M2 screws are shown in red.
The M1 screws are shown in orange.
Gently separate the display from the chassis.
Slowly spread the display and chassis until the inside of the device is reachable.
Again, using a spudger tool, release the rear facing camera from the light swap display.
Carefully remove the light swap display from the chassis by applying pressure to the circuit board.
Using a soldering iron, desolder they broken USB port.
Solder your replacement USB port onto the light swap package.
6 участников успешно повторили данное руководство.
