Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement
Выберете то, что вам нужно
  1. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Back Cover Removal: шаг 1, изображение 1 из 1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Battery Removal: шаг 2, изображение 1 из 2 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Battery Removal: шаг 2, изображение 2 из 2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 1: шаг 3, изображение 1 из 2 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 1: шаг 3, изображение 2 из 2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 2: шаг 4, изображение 1 из 3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 2: шаг 4, изображение 2 из 3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 2: шаг 4, изображение 3 из 3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, System components: шаг 5, изображение 1 из 1
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Remove motherboard connectors: шаг 6, изображение 1 из 3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Remove motherboard connectors: шаг 6, изображение 2 из 3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Remove motherboard connectors: шаг 6, изображение 3 из 3
    • Gently unsnap the 3 motherboard connectors for the touch screen assembly with tweezers.
    • The touch screen, volume buttons, and power/screen lock button assembly can now be removed.
Заключение
16 участников успешно повторили данное руководство.
Christopher Weaver
Участник с: 09/25/14
984 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 1-4, Brown Fall 2014 Участник USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 членов
Автор 7 руководств
Один комментарий
next pic i whant this information touch change....
prakash prakash - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 16,019
