Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement
Выберете то, что вам нужно
  1. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Back Cover Removal: шаг 1, изображение 1 из 1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Battery Removal: шаг 2, изображение 1 из 2 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Battery Removal: шаг 2, изображение 2 из 2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Screen Separation part 1: шаг 3, изображение 1 из 2 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Screen Separation part 1: шаг 3, изображение 2 из 2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Screen Separation part 2: шаг 4, изображение 1 из 3 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Screen Separation part 2: шаг 4, изображение 2 из 3 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Screen Separation part 2: шаг 4, изображение 3 из 3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, System components: шаг 5, изображение 1 из 1
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Motherboard Connector Removal: шаг 6, изображение 1 из 3 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Motherboard Connector Removal: шаг 6, изображение 2 из 3 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Motherboard Connector Removal: шаг 6, изображение 3 из 3
    • With tweezers, gently undo the motherboard connector for the vibrator, headphone jack and camera flash assembly.
  7. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 1: шаг 7, изображение 1 из 2 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 1: шаг 7, изображение 2 из 2
    • With tweezers, gently pry upward on the rectangular metal piece on the back of the camera flash.
  8. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 2: шаг 8, изображение 1 из 2 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 2: шаг 8, изображение 2 из 2
    • With tweezers, gently pry upward on the vibrator.
  9. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 3: шаг 9, изображение 1 из 2 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 3: шаг 9, изображение 2 из 2
    • With tweezers, gently pry upward on the headphone jack.
  10. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 4: шаг 10, изображение 1 из 2 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 4: шаг 10, изображение 2 из 2
    • With tweezers, gently pry up on the proximity sensor.
  11. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 5: шаг 11, изображение 1 из 3 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 5: шаг 11, изображение 2 из 3 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 5: шаг 11, изображение 3 из 3
    • The entire assembly can now be removed.
Заключение
8 участников успешно повторили данное руководство.
Leonardo Jaramillo
Участник с: 09/25/14
87 Репутация
1 руководство автора
Команда
USF Tampa, Team 1-4, Brown Fall 2014 Участник USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 2,709
