Введение
This replacement guide for the Nook HD+ requires the use of a soldering iron which should not be used by children, and if mishandled could lead to extreme injury.
Запчасти
Никакие детали не требуются.
  1. Pry the front frame off of the nook by wedging the plastic opening piece between the frame and the nook.
    • Pry the front frame off of the nook by wedging the plastic opening piece between the frame and the nook.
  2. Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit. Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
    • Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Carefully remove the center chassis from the bottom frame. Carefully remove the center chassis from the bottom frame.
    • Carefully remove the center chassis from the bottom frame.
  4. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Detach the battery ribbon from the motherboard. Detach the battery ribbon from the motherboard. Detach the battery ribbon from the motherboard.
    • Detach the battery ribbon from the motherboard.
  6. Flip the center chassis so that the screen is facing down, and the hole is positioned in the bottom right corner.
    • Flip the center chassis so that the screen is facing down, and the hole is positioned in the bottom right corner.
  7. Remove the wire from the attachment on the motherboard (this wire un-clips). Remove the wire from the attachment on the motherboard (this wire un-clips).
    • Remove the wire from the attachment on the motherboard (this wire un-clips).
  8. Apply soldering iron to the wire where it connects on the frame side. Remove wire when the solder is molten. Apply soldering iron to the wire where it connects on the frame side. Remove wire when the solder is molten.
    • Apply soldering iron to the wire where it connects on the frame side. Remove wire when the solder is molten.
  9. Replace new antenna following all the steps in reverse. Replace new antenna following all the steps in reverse.
    • Replace new antenna following all the steps in reverse.
Заключение
Elijah Gonsalves
Участник с: 24.10.2014
914 Репутация
Автор 3 руководств
Команда
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Member of UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 5
За 30 дней: 14
За всё время: 745
