Введение
Steps to replace a broken speaker in the Nook HD+ tablet.
Запчасти
Никакие детали не требуются.
  1. Wedge the plastic opening piece underneath the bottom left hand corner of the front frame
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame
      • Pry open the front frame.
  2. Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit.
    • Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit.
    • Carefully remove the bottom frame from center chassis.
    • Detach the battery ribbon from the motherboard.
    • Flip the center chaise onto the screen side with the hole positioned on the bottom right hand corner.
    • In the bottom left hand corner remove the 3 screws that at attached to the speaker
    • Disconnect the small red and black ribbon connected to the speaker from the white clip on the mother board.
    • Replace old speaker with new speaker then follow instructions in reverse order to reassemble
Заключение
Alex Pelicas
Участник с: 17.10.2014
259 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Member of UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 4
За всё время: 485
