Введение
This guide will show you how to remove and replace the cover of your Nook HD+.
Запчасти
Никакие детали не требуются.
  1. Wedge the plastic opening tool underneath the frame at the bottom left hand corner of the Nook HD+ and begin prying open the front frame. Note there will be glue and be careful not to brake the clips. Note there will be glue and be careful not to brake the clips.
    • Wedge the plastic opening tool underneath the frame at the bottom left hand corner of the Nook HD+ and begin prying open the front frame.
      • Note there will be glue and be careful not to brake the clips.
  2. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Apply glue round the inside perimeter of the new frame on the clip side.
    • Apply glue round the inside perimeter of the new frame on the clip side.
  4. Line up the new frame with the bottom left hand edge of the frame lined up with the hole on the center chaise push down on the frame until all the clips pop back into the slot the belong.
    • Line up the new frame with the bottom left hand edge of the frame lined up with the hole on the center chaise push down on the frame until all the clips pop back into the slot the belong.
      • Run finger around the entire frame making sure all the clips are in place.
      • Let glue dry.
Заключение
Alex Pelicas
Участник с: 17.10.2014
259 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Member of UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 1
За 7 дней: 2
За 30 дней: 5
За всё время: 544
