Введение
This guide shows how to replace the Nook HD+ volume and power button housings in 4 easy to understand steps. The tools needed to replace this piece of the Nook HD+ are the plastic opening tool, a T5 screwdriver, and tweezers.
No hazards are present in this guide, but be mindful of how rough the motherboard and ribbons are treated.
Выберете то, что вам нужно
Open the plastic frame by wedging the plastic iFixit opening tool under the plastic frame to remove adhesive.
Pop up all plastic tabs that secure the frame to the chassis.
Remove twenty 5.0 mm Torx T5 screws that hold the chassis to the back casing.
Disconnect battery from motherboard.
Remove back casing.
Remove three 5.0 mm Torx T5 screws that secure buttons to chassis.
Slide button assembly up and out of the chassis.
