Запчасти
Никакие детали не требуются.
  1. Flip the phone over to view the back. Remove the power and phone cords. Remove the power and phone cords.
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Remove the seven 8mm Phillips #2 screws.
    • Remove the seven 8mm Phillips #2 screws.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Lift up the back cover slowly because there are still wires attached to the circuit board. Lifting the back cover should not require a lot of force; simply lift with your fingertips.
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  5. Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  6. Remove the six 8mm Phillips #2 screws. Pull the speaker phone cover straight up.
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
Заключение
Elizabeth
Участник с: 21.01.2012
160 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 10-35, Amido Winter 2012 Member of Cal Poly, Team 10-35, Amido Winter 2012
CPSU-AMIDO-W12S10G35
4 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 5
За всё время: 993
