Nostalgia Electrics RHP-310 Replacing Fan Replacement
Выберете то, что вам нужно
  1. Nostalgia Electrics RHP-310 Replacing Fan Replacement, Power Switch: шаг 1, изображение 1 из 1
    • Unplug the popper.
    • Lift the lid up to remove it.
  2. Nostalgia Electrics RHP-310 Replacing Fan Replacement: шаг 2, изображение 1 из 1
    • Lay the popper on its side.
    • Remove the five 12mm Philips #2 screws around the perimeter of the base with the Phillips #2 screwdriver.
    • Remove the two 15mm Philips #2 screws in the center of the base with the Phillips #2 screwdriver.
    • Put the removed screws in a safe place, they will be needed later to reattach the housing to the base.
  3. Nostalgia Electrics RHP-310 Replacing Fan Replacement: шаг 3, изображение 1 из 1
    • Flip the base over to view the interior of the base panel.
    • Unscrew the two 10 mm Philips #2 screws from the base panel.
    • Remove the base and set it aside.
  4. Nostalgia Electrics RHP-310 Replacing Fan Replacement: шаг 4, изображение 1 из 2 Nostalgia Electrics RHP-310 Replacing Fan Replacement: шаг 4, изображение 2 из 2
    • Locate the power switch connected to the side of the housing.
    • Pinch the sides of the power switch.
    • Push the power button up and out of the housing.
  5. Nostalgia Electrics RHP-310 Replacing Fan Replacement: шаг 5, изображение 1 из 1
    • Remove the wires connected to the power switch that should be detached from the housing.
    • Gently pry the wires loose from the power switch with the plastic opening tool.
    • The wires should easily pop out from the power switch.
  6. Nostalgia Electrics RHP-310 Replacing Fan Replacement: шаг 6, изображение 1 из 1
    • Remove the power switch from the housing unit.
    • You can now replace the power switch, if necessary.
  7. Nostalgia Electrics RHP-310 Replacing Fan Replacement, Replacing Housing: шаг 7, изображение 1 из 2 Nostalgia Electrics RHP-310 Replacing Fan Replacement, Replacing Housing: шаг 7, изображение 2 из 2
    • Gently remove the heating component from the popper.
    • Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
    • Save the screws from this step. You will need them to connect the new housing to the white top.
  8. Nostalgia Electrics RHP-310 Replacing Fan Replacement: шаг 8, изображение 1 из 1
    • Remove the white top from the housing.
  9. Nostalgia Electrics RHP-310 Replacing Fan Replacement, Replacing Fan: шаг 9, изображение 1 из 1
    • Unscrew the three 10 mm Philips #2 screws that hold the heating component together.
    • Keep the screws in a safe place. You will need them to put the heating component back together.
  10. Nostalgia Electrics RHP-310 Replacing Fan Replacement: шаг 10, изображение 1 из 1
    • Pull the heating component apart.
  11. Nostalgia Electrics RHP-310 Replacing Fan Replacement: шаг 11, изображение 1 из 2 Nostalgia Electrics RHP-310 Replacing Fan Replacement: шаг 11, изображение 2 из 2
    • Locate the fan.
    • Pull the fan off the motor.
    • Do not pull too hard or you will break the motor.
  12. Nostalgia Electrics RHP-310 Replacing Fan Replacement: шаг 12, изображение 1 из 1
    • You can now replace the fan. If there is debris, clean it out.
Заключение
Еще один человек закончил это руководство.
Dana Clarke
Участник с: 09/26/12
50 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 16-57, Forte Fall 2012 Участник Cal Poly, Team 16-57, Forte Fall 2012
CPSU-FORTE-F12S16G57
5 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 785
