Выберете то, что вам нужно
Lay the popper on its side.
Remove the five 12mm Philips #2 screws around the perimeter of the base with the Phillips #2 screwdriver.
Remove the two 15mm Philips #2 screws in the center of the base with the Phillips #2 screwdriver.
Flip the base over to view the interior of the base panel.
Unscrew the two 10 mm Philips #2 screws from the base panel.
Remove the base and set it aside.
Locate the power switch connected to the side of the housing.
Pinch the sides of the power switch.
Push the power button up and out of the housing.
Remove the wires connected to the power switch that should be detached from the housing.
Gently pry the wires loose from the power switch with the plastic opening tool.
Remove the power switch from the housing unit.
You can now replace the power switch, if necessary.
Gently remove the heating component from the popper.
Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
Unscrew the three 10 mm Philips #2 screws that hold the heating component together.
Take the heating coil out of complete heating component.
Visually check the wires for frayed wires.
Make sure that the wires are completely connected to a port.
If you see a wire that is not connected, solder it back into place.
Also, use a digital multi-meter to check to make sure there is a current through the wire. If the meter does not read, you might need to replace all the wires.
