Введение
This guide will show you how to replace a motherboard. Replacing the motherboard will require frequent soldering.
Выберете то, что вам нужно
Place the plastic opening tool between the front and rear cover and pry up on each corner of the cover.
Remove the two plugs for the screen by pulling up and away from the motherboard.
Remove the plug for the cameras by pulling the plug up and away from the motherboard.
Еще один человек закончил это руководство.
