Введение
This guide shows the reader how to replace the effect button cover. If this plastic part is damaged and doesn't touch the circuit board when pressure is applied, it is likely responsible for an unresponsive effects button.
Выберете то, что вам нужно
Turn the Numark N4 over so that the bottom panel is facing upwards.
Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
Loosen and remove the 11 12mm screws from the circuit board using Phillips #2 screwdriver.
2 участников успешно повторили данное руководство.
