Запчасти
Никакие детали не требуются.
  1. Flip over the turntable and remove the 9 screws on the outer edges. Flip over the turntable and remove the 9 screws on the outer edges.
    • Flip over the turntable and remove the 9 screws on the outer edges.
  2. Remove the back cover by pulling it apart.
    • Remove the back cover by pulling it apart.
  3. Remove the clip located on the backside of the audio jack housing by gently pulling it out. There will be some resistance but continue to pull gently. The clip is located right underneath the audio jacks.
    • Remove the clip located on the backside of the audio jack housing by gently pulling it out.
    • There will be some resistance but continue to pull gently.
    • The clip is located right underneath the audio jacks.
  4. Remove the screw that connects the black wire of the tone arm to the base of the audio jack housing. Remove the screw that connects the black wire of the tone arm to the base of the audio jack housing. Remove the screw that connects the black wire of the tone arm to the base of the audio jack housing.
    • Remove the screw that connects the black wire of the tone arm to the base of the audio jack housing.
  5. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  6. Gently pull the wire that you just unscrewed to release it from the clip. Gently pull the wire that you just unscrewed to release it from the clip.
    • Gently pull the wire that you just unscrewed to release it from the clip.
  7. Remove the two screws connecting the circuit board to the tone arm. Remove the two screws connecting the circuit board to the tone arm. Remove the two screws connecting the circuit board to the tone arm.
    • Remove the two screws connecting the circuit board to the tone arm.
  8. Remove the two remaining screws connecting the tone arm to the device. Remove the two remaining screws connecting the tone arm to the device.
    • Remove the two remaining screws connecting the tone arm to the device.
  9. Flip the turntable back over to the top side.
    • Flip the turntable back over to the top side.
    • Remove the counter weight located at the back of the tone arm.
  10. Push out the pin keeping the tone arm in place using a Phillips #00 screwdriver. Once you have pushed the pin out with the screwdriver, pull the rest of it out using your hand. Once you have pushed the pin out with the screwdriver, pull the rest of it out using your hand.
    • Push out the pin keeping the tone arm in place using a Phillips #00 screwdriver.
    • Once you have pushed the pin out with the screwdriver, pull the rest of it out using your hand.
  11. Pick up the tone arm and point the back end of it towards its base. Push the back end of the tone arm into the hole. Flip the turntable over and pull the tone arm all the way through the hole.
    • Pick up the tone arm and point the back end of it towards its base.
    • Push the back end of the tone arm into the hole.
    • Flip the turntable over and pull the tone arm all the way through the hole.
Заключение
2 участников успешно повторили данное руководство.
Nikolai
Участник с: 12.10.2011
161 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 17-14, Regan Fall 2011 Member of Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 членов
Автор 7 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 3
За 7 дней: 9
За 30 дней: 77
За всё время: 4,886
