Выберете то, что вам нужно
Remove the clip located on the backside of the audio jack housing by gently pulling it out.
The clip is located right underneath the audio jacks.
Remove the screw that connects the black wire of the tone arm to the base of the audio jack housing.
Flip the turntable back over to the top side.
Remove the counter weight located at the back of the tone arm.
Push out the pin keeping the tone arm in place using a Phillips #00 screwdriver.
Once you have pushed the pin out with the screwdriver, pull the rest of it out using your hand.
Pick up the tone arm and point the back end of it towards its base.
Push the back end of the tone arm into the hole.
Flip the turntable over and pull the tone arm all the way through the hole.
3 участников успешно повторили данное руководство.
