Введение
The fan can become warped or broken which can lead to overheating and noise. This is how to replace this main fan.
Выберете то, что вам нужно
Remove these six screws (0.5 inch 5 gauge phillip's head)
Note: 2 of the screws will be star shaped circled in blue
Lift the bottom panel off
Unscrew and remove these six phillip's screws. (0.5 inch 5 gauge phillips)
Note: The screws circled in blue are 1/8" longer and have a slightly different top than the rest. These are the only two screws that are different than the rest.
Insert pry tool in between the two plastic pieces to separate them
Move pry tool back and forth from right to left until the two pieces begin to separate as shown.
Pry the two pieces apart with your hands as shown in the picture to finish separating the pieces.
This completes the disassembly of the main body of the blender so you can continue to perform replacements on the internal parts.
Remove this hex nut with the adjustable wrench.
Be sure to hold the fan still GENTLY while unscrewing the nut so the bolt does not spin with the nut.
To reassemble your device, follow these instructions in reverse order along with the body disassembly guide.
2 Комментариев
Buenas noches.
¿Cómo puedo comprar una tarjeta de esta licuadora?
Anyone know where I can get a replacement fan? Google isn't turning up anything for me. :-(
