Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement
Выберете то, что вам нужно
  1. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement, Nutri Ninja Ninja Blender Duo BL641 Body Disassembly: шаг 1, изображение 1 из 1
    • Turn blender upside down
  2. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: шаг 2, изображение 1 из 2 Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: шаг 2, изображение 2 из 2
    • Remove these six screws (0.5 inch 5 gauge phillip's head)
    • Note: 2 of the screws will be star shaped circled in blue
    • Lift the bottom panel off
  3. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: шаг 3, изображение 1 из 1
    • Unscrew and remove these six phillip's screws. (0.5 inch 5 gauge phillips)
    • Note: The screws circled in blue are 1/8" longer and have a slightly different top than the rest. These are the only two screws that are different than the rest.
  4. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: шаг 4, изображение 1 из 3 Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: шаг 4, изображение 2 из 3 Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: шаг 4, изображение 3 из 3
    • Insert pry tool in between the two plastic pieces to separate them
    • Move pry tool back and forth from right to left until the two pieces begin to separate as shown.
    • Pry the two pieces apart with your hands as shown in the picture to finish separating the pieces.
  5. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: шаг 5, изображение 1 из 1
    • This completes the disassembly of the main body of the blender so you can continue to perform replacements on the internal parts.
  6. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement, Motherboard: шаг 6, изображение 1 из 1
    • Remove the phillip's screws from the motherboard.
  7. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: шаг 7, изображение 1 из 1
    • Flip the motherboard over.
  8. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: шаг 8, изображение 1 из 1
    • Remove any plugs from the motherboard.
  9. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: шаг 9, изображение 1 из 1
    • Desolder wires and cords. Replace old motherboard with new one, and resolder wires and cords.
Заключение
2 участников успешно повторили данное руководство.
Will Jones
Участник с: 09/26/17
155 Репутация
1 руководство автора
Команда
Cal Poly, Team S7-G1, Banghart Fall 2017 Участник Cal Poly, Team S7-G1, Banghart Fall 2017
CPSU-BANGHART-F17S7G1
5 членов
Автор 6 руководств
Один комментарий
Hello Will - thank you for that lesson. I am from Canada, going to CUBA and my Cuban friend needs the motherboard for a similar blender (BL 770-2.) Where do I buy one? Thanks.
Judith Falardeau - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 16
За последние 30 дней: 36
За всё время: 1,145
