Введение
The drive socket in your Nutribullet Rx #NB-301 can become loose over time due to frequent usage. When this happens, the drive gear becomes wobbly, causing it to get stuck and stop turning. Fortunately, the drive socket can be replaced. If you are experiencing this issue with your Nutribullet Nutrient Extractor #NB-301, follow this guide to replace the drive socket and start using your blender again!
Выберете то, что вам нужно
Flip the blender over so the bottom is facing up.
Use a Phillips #2 screwdriver to remove the four 10 mm screws from the base of the blender.
Remove the base cover from the blender.
Clamp down on the nut above the socket with the needle nose pliers so it stays in place for the next step.
Lay the blender on its side and hold the drive socket with the needle nose pliers to keep in from turning so you can remove the screw.
Use a Phillips #2 screwdriver to remove the screw securing the drive socket.
Remove all dust and residue from the area before you replace your new drive socket.
Place the bottom cover back on the blender.
Use the Phillips #2 screwdriver to replace the four 10 mm screws on the back cover back.
