Введение
This will be a step-by-step guide to remove the battery assembly from the Nvidia Shield. This will need to be performed to install a new battery into the device. The user will not need any special skills beforehand to successfully remove the battery. The user can put the device back together with a new battery installed by following the steps in reverse. Replacing the battery in a Nvidia Shield can help improve the quality of the battery life of the product. If you notice the battery swelling or smoking, before proceeding check out the guide for what to do with a swollen battery.
Запчасти
Детали не указаны.
  1. Unscrew the 7 6.4mm T5 Torx screws from the back panel (screws highlighted in the photo). Use the spudger to separate the front and back panels. Use the spudger to separate the front and back panels.
    • Unscrew the 7 6.4mm T5 Torx screws from the back panel (screws highlighted in the photo).
    • Use the spudger to separate the front and back panels.
  2. The green grill is not screwed in so it can be pulled right out. The green grill is not screwed in so it can be pulled right out.
    • The green grill is not screwed in so it can be pulled right out.
  3. Remove the six 6.5mm T5 Torx screws (screws highlighted in the photo). Remove the power wires. Peel back the copper tape and remove the black and white wires.
    • Remove the six 6.5mm T5 Torx screws (screws highlighted in the photo).
    • Remove the power wires.
    • Peel back the copper tape and remove the black and white wires.
  4. Pull the battery apparatus out once all cables are removed.
    • Pull the battery apparatus out once all cables are removed.
Заключение
4 участников успешно повторили данное руководство.
Andrew Barbanera
Участник с: 20.09.2014
364 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 1-1, Hickman Fall 2014 Участник USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 членов
Автор 12 руководств
Комментариев: 2
For replacement batteries, are they 18650? Do I want flat top or button tops?
evan - Ответить
Hello,
any idea what connector the battery uses? I have a replacement pack but they put the cable on the wrong side of the pack (doesn’t fit backwards either)
Brett - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 11
За последние 30 дней: 47
За всё время: 4,214
