Введение
This repair guide shows how to replace the motherboard for a Nvidia Shield Controller Gen 2, manufactured by Nvidia, item model number: 945-12920-2500-000.
The motherboard is a circuit board which connects all the components within a device. If the motherboard is faulty, the controller may not turn on at all.
Выберете то, что вам нужно
Use a Torx TR6 screwdriver to remove the six 7mm screws from the back of the controller.
Use the Torx TR6 bit to remove the two 7mm screws behind the analog sticks.
Unplug the power supply cable from the analog stick assembly.
Use a pair of tweezers to unplug the rumble motors from the motherboard.
Use a pair of tweezers to unplug the battery cable from the motherboard.
Use a Torx TR6 screwdriver to remove the two 7mm screws towards the top of the frame.
Use the Torx T5 screwdriver to remove the two 5mm screws in the bottom corners of the frame.
Lift out the motherboard from the case.
3 участников успешно повторили данное руководство.
