Введение
This guide will demonstrate how to replace the motherboard in the Nvidia Shield Controller. This replacement does not have many steps but deals with multiple small components that can be difficult to maneuver.
  1. Use a Torx TR6 screwdriver to remove the six 7mm screws from the back of the controller. Use a Torx TR6 screwdriver to remove the six 7mm screws from the back of the controller. Use a Torx TR6 screwdriver to remove the six 7mm screws from the back of the controller.
    • Use a Torx TR6 screwdriver to remove the six 7mm screws from the back of the controller.
  2. Use a plastic opening tool to pry open the back frame of the controller. Use a plastic opening tool to pry open the back frame of the controller.
    • Use a plastic opening tool to pry open the back frame of the controller.
  3. Use the Torx TR6 bit to remove the two 7mm screws behind the analog sticks. Unplug the power supply cable from the analog stick assembly. Unplug the power supply cable from the analog stick assembly.
    • Use the Torx TR6 bit to remove the two 7mm screws behind the analog sticks.
    • Unplug the power supply cable from the analog stick assembly.
  4. Use a pair of tweezers to unplug the rumble motors from the motherboard. Use a pair of tweezers to unplug the battery cable from the motherboard. Use a pair of tweezers to unplug the battery cable from the motherboard.
    • Use a pair of tweezers to unplug the rumble motors from the motherboard.
    • Use a pair of tweezers to unplug the battery cable from the motherboard.
  5. Use a Torx TR6 screwdriver to remove the two 7mm screws towards the top of the frame. Use the Torx T5 screwdriver to remove the two 5mm screws in the bottom corners of the frame. Lift out the motherboard from the case.
    • Use a Torx TR6 screwdriver to remove the two 7mm screws towards the top of the frame.
    • Use the Torx T5 screwdriver to remove the two 5mm screws in the bottom corners of the frame.
    • Lift out the motherboard from the case.
Заключение
2 участников успешно повторили данное руководство.
Nate Hale
Участник с: 16.09.2020
299 Репутация
Автор 2 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 30
За всё время: 355
